Start Optistruct from Script, extract values from analysis back.
User: "Merula_20758"
Altair Community Member
Updated by Merula_20758
I am fairly new to scripting and began to do a simple test on how to do an automated optimization.
So I created a cube, meshed it, put some loads and bcs on it and tried to run it. Now the problem is: I only can fe export my data and not get optistruct to run automatically. What I later want to do is for example: Do several optimization with different volume frac upper values like 0.3 0.4 0.5 and extract the movement of a node back into my script.
So, as I see it, two questions emerge:
1) How can I call an Optistruct run from within the script
2) How can I extract a value (like displacement of node 1) back into my script.
I know there is Hyperstudy, but that is not my intention. I want the process to be fully automated at the end.
Thanks for your help,
Merula
1 - 8 of 81
    User: "tinh"
    Updated by tinh
    Hi
    to invoke an application from tcl:
    exec $AppPath [app options] &
    if you want to run it and wait for completed, remove '&' (but not much recommend once tcl core cannot allocate enough memory)
    to extract displacement, load result into hypermesh or hyperview, looking for relevant commands to query result in help ( i am sorry i do not ever use them so i am not sure)  image/emoticons/default_rolleyes.gif' alt=':rolleyes:'>
    OP
    thanks for your help. I did not get it to work until now. Still hanging on the job starting code
    So, I try to open an optistruct run with the optistruct.exe which is located at: 'C:\Program Files\Altair\13.0\hwsolvers\common\tcl\tcl8.5.9\win64\bin\wish85t.exe' 'C:\Program Files\Altair\13.0\hwsolvers\scripts\hwsolver.tcl' -solver OS -icon
    If I try to implement this:
    exec 'C:/Program Files/Altair/13.0/hwsolvers/common/tcl/tcl8.5.9/win64/bin/wish85t.exe' 'C:/Program Files/Altair/13.0/hwsolvers/scripts/hwsolver.tcl' &
    It tells me no input file. So I add my input file, which gives me this:
    exec 'C:/Program Files/Altair/13.0/hwsolvers/common/tcl/tcl8.5.9/win64/bin/wish85t.exe' 'C:/Program Files/Altair/13.0/hwsolvers/scripts/hwsolver.tcl' 'C:/Temp/Run/Optimization.fem'  &
    This returns the image in the attachments... whats wrong?
    <?xml version="1.0" encoding="UTF-8"?>post-9178-0-01084500-1444665097_thumb.jp
    User: "Altair Forum User"
    Updated by Altair Forum User
    To run Optistruct, try:
    C:\Program Files\Altair\13.0\hwsolvers\scripts\optistruct.bat mymodel.fem
    OP
    Lilke this?
    exec 'C:/Program Files/Altair/13.0/hwsolvers/scripts/optistruct.bat' 'C:/Temp/Run/Optimization.fem' &
    Cause nothing happens when I put it like this.
    User: "tinh"
    Updated by tinh
    Lilke this?
    it is running in batch mode
    if you want to show the console, try
    exec cmd /K start 'C:/program.../optistruct.bat' 'C:/temp... .fem' &
    OP
    Ah sorry,
    the thing was, I checked with the task manager, that there is no optistruct job starting.... but as it turned out, I just was not fast enough. My simple model does not take a hudge amount of time to run image/emoticons/default_biggrin.png' alt=':D' srcset='/emoticons/biggrin@2x.png 2x' width='20' height='20'>
    So thanks, that problem is solved.
    Is there a command.cmf file for hyperview or somethin similar for me to extract the code necessary for my script?
    Best regards,
    Merula
    User: "tinh"
    Updated by tinh
    Hi
    There is no command file for hyperview
    But you can find sample code in HW Reference Guide
    OP
    Thanks, I will check that.
