How to use trigonometric functions in command files?
User: "Yann_Le_Floch"
Updated by Yann_Le_Floch
In order to use trigonometric functions in command file (py files), you have to specify or to load the library that contains these functions. For that, there are two possibilities:
Solution 1
In the python file, add the line: from math import * This line allows using directly the function cos, sin, cosd, sind…
Solution 2
In the python file, add the line: import math This line allows the math module download. Then, in order to use the functions, you have to type math.cos(), math.sin(), math.cosd(),math.sind()…
Comments
No comments on this post.
