Fixed Points on Solids without surfaces
User: "Merula_20758"
Altair Community Member
Updated by Merula_20758
I want to do a simple topology optimization with a solid cube as a design space. In this cube I want to define a set of points which act as points for forces or SPCs. I have found no way but to trim the solid with several surfaces in order to make the fixed point marked for the meshing process.
Is there no better way for this? I would like to define a statement like: Mesh this solid, BUT set your mesh on these points too as an additional mesh constraint. WIth surfaces it is possible but not with solids?
Thanks in advance,
Merula
1 - 7 of 71
    User: "tinh"
    Updated by tinh
    Hi
    if it is not possible for solids, you can delete the solid but keep its surfs
    enter F11> add/remove points to add fixed points.
    OP
    So I delete the solid but not its surfaces, mesh the surfaces (but the fix points do not lie within the outer surfaces) and what then? solid map general?
    The proble really is that those points are in the middle of the solid an I would like to skip the necessity to devide the solid with a surf going through each node.
    best reagrds,
    Merula
    User: "tinh"
    Updated by tinh
    Hi
    sorry for mis-understanding your mean
    to trim a solid, enter geom>solid edit> trim with plane
    OP
    Hi tinh,
    thats the way I did it in the first place but I ended up with 64 solids on this little example, which is not very satisfying, as it should be possible without any division of the main solid (at least to my understanding)
    Merula
    User: "tinh"
    Updated by tinh
    So it is simple that just mesh the solid then F3 closest nodes to the given points
    if you got quality issue, manually modify it (translate, smooth...)
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    What i understood from above mail is you have solid with some points inside.While meshing node should come on these points location.
    Such functionality is underdevelopement for Simlab preprocessor.
    Regards
    Rahul R
    OP
    any Updates on this? I would really like to see this functionality in hypermesh.
    Best regards,
    Merula
