Simple Loop question
Hey guys,
I declared a bunch of points using variables for the coordinates.
variable x1,y1,z1, x2,y,2,z2, .... in sum 20 points
Now I want to create notdes, but my statement does not seem to work:
for {set i 1} {$i < 20} {incr i} {
*createnode $[eval x$i] $[eval 'y'$i] $[eval 'z'$i] 0 0 0
So I want to read x1 and 1 is i , which gets incremented. I think it is just a simple tcl syntax error, but I am not getting the solution. Tried append, eval, expr... none of them lets me call $x1.
Thanks and best regards /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
Merula
If you can save coordinates into list, maybe this code can help:
set xx {1 2 3 4 5}
set yy {11 12 13 14 15}
set zz {21 22 23 24 25}
foreach x $xx y $yy z $zz {
puts '$x $y $z'
#do something with x y z
}0 -
Hey,
thanks for the tip. It is working with plain numbers. But as I try to:
set xx {$x1 $x2 $x3 $x4....}
it interprets those as strings. Does not read whats in x1 2 3 ...
So unfotunately no luck
0 -
Try this:
# Data
set x1 1; set x2 2; set x3 3; set x4 4; set x5 5;
set y1 11; set y2 12; set y3 13; set y4 14; set y5 15;
set z1 21; set z2 22; set z3 23; set z4 24; set z5 25;
# List
set xx [list $x1 $x2 $x3 $x4 $x5]
set yy [list $y1 $y2 $y3 $y4 $y5]
set zz [list $z1 $z2 $z3 $z4 $z5]
# Loop
puts '$x $y $z'
}0 -
Success!
Thanks!
