Hi guys,
Lets say I have a design space modeled as a geometry file. I have a set of cylinders modeled as 1D Beam Elements which should all lie within the design space box.
The idea is to use a contact adjustment calculation (=contact initializatio) between the cylinders and the design space.
I tried to model it with a two contact surfaces but the elements (1D) are not valid.... is this even possible to do with Hypermesh?
I wrote the problem with illustrations into the attached .pdf file.
Any help is greatly appreciated!
Thanks!
Merula
