<body> <h1> Convert NURBS to polymesh </h1> <hr> <p> This step is mandatory to ensure object integrity for 3D printing.</p> <ol> <li> Select PolyNURBS - NURBS to Poly </li> <li> Select the object and right click </li> <li> In the control panel, change the Options from View Tessellation to Advanced Tessellation </li> <li> To control the mesh density, enable Face Dimension and enter desired value. Lower face dimension = higher density = larger file size </li> <li> Click the green check mark to accept changes and close the tool </li></ol> <p><img src = "tess_options.png" align="middle"></p> </p> </body>
