Here i can see that i can export the data as an excel file , would it be possible to import the data from an excel file to Fluxmotor?
Hello Ali,
In Supervisor < part library < Under User < Select the type of part you want to import < New.
Import the .xls file by clicking on search icon.
Thank you,
Lavanya
Hello Ali, In Supervisor < part library < Under User < Select the type of part you want to import < New. Import the .xls file by clicking on search icon. Thank you, Lavanya
Thank you Lavanya for your respond but I want to import even the outer and inner diameter (I want to change on Fluxmotor just by importing an excel file or even creating a new Motor), is that possible?
When importing a custom part to FluxMotor, it will not be parameterized. You need to have the same values as the outer and inner dimensions of the model from which you created the part.
