How can I write the error messages in HyperMesh that are written in the bottom left corner to a file? Or are they automatically written to a file?
Hi Franziska,
To display an error message in HM, you can use hm_errormessage command.
For more details, refer link below.
https://help.altair.com/hwdesktop/hwd/topics/reference/hm/hm_errormessage.htm
Bhavik
Hi Bhavik,
if I use hm_errormessage, I can write my own messages, right? But I want to write the messages, that result by using a command that does not work properly.
Here one excample: *edgesmarksuppress 1 30 --> You will see a red zero in the Tcl Console and you will see the error message "Lines have not been selected" in the lower left corner. I am trying to write that error message to a file.
One way I tested is:
set log_file [open "logfile.txt" w]
if {[catch {*edgesmarksuppress 1 30} errorMsg]} {puts $log_file "Error occurred: $errorMsg"}
But that way only writes "Error occurred: 0" to the file.
If I would use HyperMesh in batch mode, then I can write those messages to a logfile. But how can I do this using HyperMesh not in batch mode?
