As seen in the below image I have to create 1D Beam elements (Bar2) in the new version.
In classic , We can create using 1D>Line Mesh>By Nodes.
What's the way in the new version.
I have to create 1D beams for contact purpose in Explicit loadcase.
have you tried this 'Beams'?
I dont want to create manual beams by selecting 2 nodes at a time, its time consuming.
In classic version there is option to select by node path, which will create it a single time under line mesh.
