Problem with License (altair_lic.dat), after launching (CAD)FEKO
Hi!
Ok, now I have managed to launch (CAD)FEKO as guided by the previous question of mine. Though, I crush into this problem (error), that seems to be something with the license:
I used the license provided to me by mail by Altair (altair_lic.dat), placed in the proper folder. Though, even when I have tried everything, I can't get (CAD)FEKO to launch as expected. And I can't recognize the error or what it says.
Could anyone help with this issue?
Thanks, in advance!
Hi @Eliasmys ,
Could you please check if there is an environment variable on your system named ALTAIR_LICENSE_PATH? The value of this environment variable should be the path to the license file.
Best regards,
Torben1 -
Torben Voigt_20420 said:
Hi @Eliasmys ,
Best regards,
TorbenHi @Torben Voigt,
Thank you for the answer and, please, forgive me for the somewhat late response.
Well, I will do this but could you guide me as to how to check the existence of such a variable on my system. I don't know how to check something like that.
Appreciate your patience and your willingness to help. Thanks, again!
I will wait for your answer!
0 -
Eliasmys said:
Hi @Torben Voigt,
1. You should check the file name extension, to make sure that the license file is not altair_lic.dat.dat
2. You could check the Altair License Path in Advanced settings >> Environment variables
1 -
James Lewis said:
Okay, sorry for not mentioning. There is a problem with that... I have Linux, in particular Ubuntu 22.04.1 LTS.
I checked the system variables by typing env in a bash and I can't see "ALTAIR_LICENSE_PATH".
Also, the path of my launch script is /media/eliasmys/Data/FEKO/altair/scripts/cadfeko:
and of the license file /media/eliasmys/Data/FEKO/altair/security/altair_lic.dat:
Finally, my license file, as I see, is properly named "altair_lic.dat":
Do I need to set a new environment variable and how?
Is there any other cause for the error? Any other way of resolving it? And, preferably, for Linux.
0 -
Also, this is the content of my license file:
# Company: Altair Engineering Inc
FEATURE HyperWorksEDU
VENDOR = ALTAIR
VERSION = 2022.0
START = 2023-01-04
END = 2024-01-04
SHARE = VIRTUAL
COMMENT = " Server Info: ETHERNET = 3c2c30bf163f"
SN = "7A2E5EA8-8CD9-11ED-9793-6868A80B4B5215"
KEY = 4SS3MSSC03PEU69GP90KB651UL6L1UBEIJSPFK02DTPLQD8NOK61BIKCR5KAK9K04QCLPQ \
27PVS4T94MAS553Q1A1HK3J85BCQ88R5FVTIEKAJOPS255L1TJS4FJNA9M56FK8242LDE7 \
UB47ADAC4JG97P5581U79B2UQ5J5380UH0HIT94615S44DT8VQPN80E7OGSDUOB2IABEC5 \
1U0TG26PDS4NQ9QJ2C1SPA31V8TUI85AR6UOCJ18ECGVVO9PG42G3MJJOSHQNFQMLV17PF \
KHL03KTDNOUUA4CKBJR6HSN3AUGU7AHAMGOFIU645KD4HBL40LNUFRTAF8GSB5U1RAU3MU \
S7KJRBFB1SPVTDFMHRPI5M07GS0SUPTM052FA7BD88KBN87F0LK7K49GAB8N16CKAL1UT1 \
BJ1S1632L22L5JHCTUR0L4QFMCE3BTM1I7H4T6H9TFF5QCCKH2BHUDNVIKG6G8OFL6Q9EE \
8NSTAKL3LGBTUJK801GU86T43LSHKNRSUD5V9RC9O3SM4ACR37BUUFG50EDGUJIGP5V286 \
UCQB0QNM014K2H6ARVIGA2P8T0H56H6H5LV88TA35TSLUV3E7DJIHJ412PPB29Q1O4LHED \
0H8OSO74P1TBJV2NFVJSVHE4T2AIMFO10
}FEATURE HyperViewTrans
VENDOR = ALTAIR
VERSION = 2022.0
START = 2023-01-04
END = 2024-01-04
SHARE = VIRTUAL
KEY = 89EUMUVI9VDQK7PF6GI8F4J4EG2SDDPEV4SA6RE5DPESP464O523HKH3VDI1JUP8SD68IV \
OQVP5VVC89GL1PFTI3UA7K84EOMV9KHGI1OB5UEJG11JIRNOOEAHSOCTBSJGB8JK66Q3HP \
8PPCVCJNM2LU9PFU5LKFQ9TC9Q7MPI3BODE2G87H03O0BR2I86TKTDJT475BKC9LJOPIC2 \
3TFL2FOV7V8LS2U65SMVQHSGCNGLD7BU9EMA5DDPOQC646JBMIH0S6AVO9LGV6FKIAADS5 \
J9MCJ5K3BM808NIQPQPOEJFPFU3SH2FE7K0Q0CT3JUQQ4BGCUP9QDJIATSM4P9G1P3C86S \
DMP7JJNU96NT5A2LPSNJ225AVVQNED295L7FHHGLPOGJ362D7NINMTP7RQ3I96V7Q16987 \
UUS34K2QBOOKHR1DE5OOR896H7DCQCPH5S5RLQRQR3IU6LH2HRTASCA5AM59AK2M7ATROH \
E00SPES30E35BKTCOTQ84MA8ATFUMH3I3P290AH1MR6HABV357LI3JPK7T27PK96JM3Q4M \
5M34LGJJ2Q4BO1NBJCQ9SIP0UMNVIEQ3OEB2CE0RAMSAHUSGIP306RBDIATJCR4URR20PB \
I5ATBP7PKH1FH9UD0LK84F7RHH1ODN3N8
}FEATURE romAI
VENDOR = ALTAIR
VERSION = 2022.0
START = 2023-01-04
END = 2024-01-04
SHARE = VIRTUAL
KEY = C0TSVK5QJ64FQ4N03L453V1U79TOV3CK4LKN04I068KI4UOR86DPE7N42MDBG971DRF34U \
UKOBTDP2CG68HMHNR1HI64HPD8CSIO4EFHTHHF6LB98MU8JJ8GGL3BMFM61FMI93GTTM78 \
3G1D90JP9V1TLAL643L437GANRBUGNN8SD0RAPSN94JII0RKCVLECP1HAQMVM04V6QJR2J \
2CBIGDGUGE735B3LDAKBKE4QHNGH0AQ4U41596HL4U8BN9RQBIPSJ1IO15R0ERC6SCT88D \
5CDTLJ7DGJDER9653OQP8U1J9F1873D2IMC7Q4I0LU9H9HN1SMS08TQ2K8A4LV9CDA0LES \
4PION1NG9OHE8DJUVN12S5IA2IN6640Q6DCM7RURLAC010463G0CVNB8BN6S42D5FNA3SE \
CRCKTMJ56PILB1CS3UNRLBHSTEK4SB736JDF4D93MAM238MCG8NH9420DJNDJPGCO2LD77 \
O17ELSTI0K9B2MHI20G3BB4NLNK82L5UPMQQRVKIB1N99Q8RL82OBHKNMBNQQSUEBIFQQ3 \
T5JS3HLU03ARNL5EIAVJA60LI3L8VGC92AM9CRVUBQJ8REMSR33JJG2BSSENOA181L21PH \
4M8JAUITCSFL8E893NNQ2QPS277Q2VNAG
I think the error might be caused, maybe, because I'm not licensed for FEKO, but for other programs. Is that possible? And, should I request a license again?
0 -
Hi @Eliasmys ,
Maybe it would be best to put a support request on Altair One.
Make sure that you select "Feko" as the product and "Licensing" as the category.
Don't forget to mention that it is Ubuntu.
Best regards,
Torben0 -
I was expiriencing a similar issue as the one Eliasmys shared above, in my case while installing ESAComp. For those having the same problem, here are the steps i went through
1. Installed program through Altair marketplace. After opening it, it seems it finds no license.
2. At the Altair marketplace in Altair one, found "Studen Edition License". I clicked it and followed the steps to get my License.
3. At the same place I downloaded ESAComp in the marketplace (It should work for any student bundle app), in the tab at the right, I clicked on the License Manager and installed it.
4. Opened the .exe of the license manager and followed the steps, indicating I would like to use a license key. Used my key and installed it. (After this step I checked if my app would work. It didn't, but it may be worth trying)
5. I serched for "ALMUtil" in the Windows search bar. Opened it and went to "Activation". Then I pasted my key again and activated it. (Again I suggest to check if it now works). In this same tab, under "User" tag, the path of the license is stated.
6. Right-clicked on the windows icon on the windows task-bar and selected System
7. Searched for Advanced System Settings, clicked on Enviroment Variables.
8. In System Variables, checked if ALTAIR_LICENSE_PATH existed. It didn't, so I clicked on "New", named it ALTAIR_LICENSE_PATH, and then pasted the license path on variable. Check the step 5. to know how to find this path.
9. After this, my app finally opened.
0 -
Hello @Alejandro Merino,
Unfortunately, I'm not using any Altair products at the time nor I engage in any associated work, so I couldn't help you or answer much. Thank you for your answer and best regards.
Elias
