Hi all,
This question may be reasonably straight forward to answer (it isn't a trick question at all).
When I perform a hyperstudy optimisation study with plate thickness being the variable. Is it possible to dictate what thicknesses I want hyperstudy to investigate? For instance, I have a structure with a plate where I want to know what thickness I can reasonably use without going over a stress limit but I also know that the thicknesses available are 5, 10, 16, 20 mm. How do I get hyperstudy to only look at those values?
Cheers
Andy
