Viewing Loadstep Subtitle In Hyperview Window Notes
Hi all,
I'd like to be able to display Loadstep Subtitles in the upper left window notes in Hyperview but cannot find a command (looking for something along the lines of {window.modeltitle}) in the help section.
Any ideas anyone?
Cheers
Andy
You can use the notes option in HyperView to give description for your model on the screen.
0 -
Hi Pranav,
Many thanks alas I should have been a bit clearer in my initial description, am aware of how to add notes on hyperview and have a standard set up template (see below), I'm looking to add to that template with the loadcase subtitle... alas the struggle.
Model: {window.shortmodelfilename}
Title: {window.modeltitle}
Boom Angle/Extension: [i.e. 0Deg / 0mm]
Loadcase: {window.loadcase}0 -
Along those lines but the loadcase subtitle is not a selectable option. Seems a bit strange to have the option in Hypermesh but no means in Hyperview to access it.
