In this EDEM GTT webinar, you'll learn how to control the motion of geometries based on the forces generated by bulk material, in a coupled simulation with EDEM and MotionSolve.
By joining this webinar, you'll learn about:
- controlling the speed of a motor through the forces exerted by particles on sensor plates.
- the workflow to control the motion of a geometry based on a force sensor.
The example during this webinar is a hopper and an inclined auger, and the speed of the auger is controlled based on the forces exerted by the bulk material on two force sensors.
Sign up here
For a step-by-step guide you can access the following tutorial on Knowledge Base article: Optimization of Bulk Handling Control System using Sensor Force Feedback with Altair EDEM, Inspire, and MotionSolve Co-simulation
