Hello all,
I was looking to add browser tabs in hypermesh window. Are there any APIs available for browser related options.
Thanks
Girish
Hi Girish
try hm_framework addtab
Thanks tinh
Hi Girish try hm_framework addtab
Hi tinh,
Do you know how to add tab in hyperview?
the code like this:
.mainFrame.center.f1.left_proj add [hwtk::pane .newTab -text 'New Tab']
Hi, the code like this: .mainFrame.center.f1.left_proj add [hwtk::pane .newTab -text 'New Tab']
tinh,
thanks.
cool~
Hey Tinh and others as well,
Thanks for helping everyone in the field of automation. I have query which is extended version of above query
Since, I had already developed a GUI using tab feature. But, due to its use on another machine (with changed screen resolution), the buttons at bottom are hidden. So I decided to add scrollbar. But no success.
Earlier My code was this -
catch {hm_framework removetab 'Test-Group A' destroy .main} set main [ frame .main ] hm_framework addtab 'Test-Group A' $main hm_framework resizetab 'Test-Group A' 440 frame $main.main_frame -height 550 -width 450 -bg '#C5E1A5' grid $main.main_frame -row 0 -column 0 -sticky w -padx 0 -pady 0 image create photo imgobj0 -file '$::script_address\JarFiles/Image/Test_Logo_222.png' -width 450 -height 130 label $main.main_frame.label0 -bg 'black' grid $main.main_frame.label0 -row 0 -column 0 -sticky w -padx 0 -pady 2 -columnspan 2 $main.main_frame.label0 configure -image imgobj0
... and so on (includes Labels, entries, buttons in vertical layout)
After implementing scrollbar and related parent frame, canvas and child frame-
catch {hm_framework removetab 'Test-Group A' destroy .main} set fmain [ frame .main ] hm_framework addtab 'Test-Group A' $fmain hm_framework resizetab 'Test-Group A' 440 #set up scrollable frame
set frmparent [frame $fmain.frmparent -width 450 -height 500 ] set canvas1 [canvas $frmparent.canvas1 -width 553 -height 600 -xscrollcommand '$frmparent.hscroll set' -width 523 -height 500 -yscrollcommand '$frmparent.vscroll set'] set main [frame $canvas1.frmscrolled]
# package require BWidget
# ScrollableFrame $frmparent
# set frmscroll [$frmparent getframe]
set hscroll [scrollbar $frmparent.hscroll -orient h -command '$canvas1 xview'] set vscroll [scrollbar $frmparent.vscroll -orient v -command '$canvas1 yview']
pack $frmparent.hscroll -side bottom -fill x pack $frmparent.vscroll -side right -fill y pack $canvas1 -expand yes -side top
$canvas1 create window 0 0 -anchor nw -window $main
$canvas1 configure -scrollregion [$canvas1 bbox all] pack $frmparent -expand yes -fill both -side top frame $main.main_frame -height 550 -width 450 -bg '#C5E1A5' grid $main.main_frame -row 0 -column 0 -sticky w -padx 0 -pady 0 image create photo imgobj0 -file '$::script_address\JarFiles/Image/Test_Logo_222.png' -width 450 -height 130 label $main.main_frame.label0 -bg 'black' grid $main.main_frame.label0 -row 0 -column 0 -sticky w -padx 0 -pady 2 -columnspan 2 $main.main_frame.label0 configure -image imgobj0
But it seems to not work.
Thanks,
In short, I can say - how do i add scrollbar to items of browser ?
