I want to create connect two surface with rbe element is there any pratical way ? how to perform it
best regards
thank you
Please find attached a help document for your reference.
Thank you.
Mr. @PrasannaK
thank you for reply without hang on but I would like to connect each node on bottom plate (red) with all nodes on top plate (blue) by using rbe element (yellow) how to perform it?
