***NEWBIE*** report design - append template - traps highlighted correct but in output first entry for 3 columns show (null)
User: "Jill Overly"
Altair Community Member
Updated by Jill Overly
Very new as in only started using Monarch this week.  I have a audit text file and I have traps for 9 fields.  I have all of them defined and in the top window of the report design I can verify that the correct data is highlighted correct for each one.  In the lower window where you see the table of data 2 of the columns have (null) as the first entry and then the first entry is actually the second entry in that column. How do I get rid of the (null) and move all entries up ?  Thanks in advance for any help. image
1 - 1 of 11
    User: "Jill Overly"
    OP
    Accepted Answer
    Exactly the problem. Once I created those as Group Footer instead of Append it worked. This is Meditech Magic. I’m loving this powerful tool. Your video was very helpful. I plan to watch more. Thank you so much.
