Hello Design Explorers,
Are you a newbie to HyperStudy and want to see a scaled down UI to filter out the noise and learn the basics? Or, are you an advanced user who wants to see all of the bells and whistles that HyperStudy has to offer?
Whether you are a newbie or an advanced HyperStudy user, you can simply select a Profile to determine the level of tools available in the UI based on your skill level.
You can select a Profile from the View menu or by clicking Profile in the bottom, right corner of the application. Currently, you can choose between the following profiles: Minimum, Introductory, Maximum or Default Settings.
And...when you are ready to analyze the results of your explorations and take full advantage of what HyperStudy has to offer, you can switch to the Post-Processing profile and expose all of the post-processing tools.
Is this helpful? Let us know your feedback!
Altair Team.
