This challenge is to run a topology optimization on the base of the Water Lilly Pad that is supported at its centre, with water pressure loads in the vertical and horizontal directions.
Note that the location of the ribs in nature is not purely based off of achieving maximum stiffness, or minimum mass, but also considers nutrient transport, and other functions necessary to the plant. We will be focusing exclusively on the structural aspects of the rib layout for this challenge. Your objective is to maximize the stiffness while reducing mass.
The attached STMOD file is your starting point. Feel free to adjust the design space, manufacturing constraints, and optimization settings to come up with the ideal massing.
Level: Easy
Product Required: Altair Inspire
The solution can be attached in the comment section of this post. The desired output format is a PNG or JPG showing the optimized rib layout, and analysis results.
The solution to Challenge Prosthetic Knee Motion Analysis can be found here:
https://community.altair.com/community?id=community_blog&sys_id=49d2c6271b59fd10c4dfdbd9dc4bcb0b
If you would like to solve more challenges and get regular challenge release updates, Subscribe to the Altair Community Challenge forum
Responses from community:
Sourav Das:
PFA my Water lily design
, Do let me know if you need more designs.
Ripfumelo:
Re-done the challenge
Sakshi Patil:
Dear sir,
Karli:
Here is my try:
1. basic
2. With Frequency Constraints
3. Topography optimation
4. With only 3 sectors in shape control
