The eLearning course, Getting Started with HyperMesh v2023, is now available on https://learn.altair.com!
In this course, you will learn about the basics of the HyperMesh v2023 interface through a series of demonstrations. You will also be introduced to some of the most used geometry, meshing, and model setup tools while setting up a linear static and a modal analysis. Model files are supplied with the demonstrations so that you can follow along within HyperMesh.
Want to get started? Click here to directly access this course.
