Learn how to create, assign, and orient orthotropic materials and observe the difference in modal analyses when the orthotropy is aligned properly with specific parts.
- Create and assign a new orthotropic material
- Run baseline modal analysis with default material orientation
- Create new design study with a local coordinate system to properly orient material properties for some parts
- Re-run modal analysis
- Compare results
