I am doing a simulation and when i export the coordinators i feel some particles are missing or the chains are broken.
Is there a way to export the coordinates of individual chains separately? or determine which chains are broken?
Hi Shyam,
No directly but in the analysis options there are measures like meta particle length:
https://help.altair.com/edem/Analyst/AnalystTree-Display.htm > Meta Particles
The length will change if the meta particle is broken. Just to note you have to be using the in-built meta-particle tool for this analysis.
Regards
Stephen
