For the HyperWorks 2021.2 release, Sketching tools have been newly introduced. Do you want to know more about this release? Learn directly from the source and watch this 1-hour webinar. Our presenters from the program management team are showing you the latest highlights about CAD, Geometry, Meshing, and Morphing.
Geometry
- Newly introduced sketching workflows that are similar to Inspire and other CAD systems. Users can create and edit sketches, and finally, convert them into lines and surfaces
- Improvements to defeaturing of fillets by introducing a Parasolid option to detect and remove fillets
- Great efficiency gains by introducing a Cut Hole tool and the addition of an auto-imprint option to geometry creation tools
Meshing
- Node associativity to geometry added which will reduce the time and effort in editing the mesh
- Panel meshing with improved face editing options
- 2D boundary layer enhancements with edge layer mesh controls
- Quick and easy way of creating hex dominant solid mesh for thin solids
Morphing
- Morph using saved Shapes.
- New Undo All Morphs button.
- Morph normal to mesh.
- Remesh while morphing.
