Hello Zheng!
It's probably because of a circle parameter configuration. Check the "Circle" options in your parameter file and make sure that, if you have a Remove treatment option, that its size is greater than the hole one.
Upon rebuild operation:
Kind regards,Paulo Libório.
Hello Zheng! It's probably because of a circle parameter configuration. Check the "Circle" options in your parameter file and make sure that, if you have a Remove treatment option, that its size is greater than the hole one. Upon rebuild operation: Kind regards,Paulo Libório.
Hello Libório
That's correct.
The hole will be kept after Rebuild if the setting is changed from Remove to Seed.
Thanks
