I am very new to FEKO, and I am not an electrical engineer. So please ELI5.
When defining a waveguide source, what is the "Magnitude (W)^1/2" in the "Fundamental Mode" options?
If I am trying to simulate a rectangular waveguide, with a 75 kW wave propagating through it, how is the appropriate "Magnitude" value calculated?
Do I need to calculate the average power density by dividing the wave power by the waveguide cross-section area, then calculate the magnitude of the electric field (E0) from the equation: S = (c*e0*E0^2)/2 ?
So if the cross-section area is 0.044 m^2, then the average power density is 1.69 MW/m^2, and E0 is 35.7 kV/m?
If the 75 kW is the peak power of the wave, do I need to divide the peak power by 2 in order to get the average power, and then use the average power to calculate the average power density?
Thanks.
