Is there a way to apply a display scale per load or per load collector? When I change the size of one load, all the loads scale accordingly.
In the image below, the horizontal load is a 6 kN force, the vertical (down) load is a 34 kN force, and the vertical (up) load is a 50 kN-m torque.
I'm using a [t, mm, N, MPa] unit system so the 50 kN-m torque is a 5*10^7 kN-mm torque, and the displayed arrow is too large to properly view all the applied loads. If I scale the torque display scale down, the other loads scale down too and I can't see them. If I scale the small force, the other loads scale up too.
I want to either scale the loads individually, or display the all the loads with the same sized arrow. Is that possible?
