Random Fatigue Analysis using FRF stresses and PSD by Abaqus result
I would like to do the random fatigue analysis using FRF stresses by Abaqus result.
In Hyperlife, we can not import the result calculated by Abaqus with PSD curve directly.
So, I should import the result for the FRF in Abaqus, and I can perform the random fatigue with PSD in Hyperlife.
When I checked the damage, it is over 100. I think it is not correct.
Could you give the advice that?
The material Aluminum.
Time: 4hours - 14400s
I will attach my odb file, FRF and PSD curve.
I'm not familiar to Abaqus, so I can't help too much.
But, can you check in a simple file, where you can validate results manually? analytical solution or something known?
If you get different results than expected, then it might be a bug. But otherwise, it could be your setup or units that might be incorrect.
