Hello, I want to apply a load on every node of a specific plane in Hypermesh. In Abaqus it is possible to define a reference point with a boundary condition, e.g. to kinematically couple degrees of freedom of other nodes to the reference point (see picture). In this case a load applied to the RP would deform all coupled nodes in the same way.
How can loads be modeled analogous to this procedure in Hypermesh using a .tcl script?
Thank's for any help.
