Use a Variable value in Expression?
User: "Carlos Fondevila"
Altair Community Member
Updated by Carlos Fondevila
Hi all,
I'm trying to use a Variable value in a Expression, for example, I've created the variable "Speed":
And I want to use it as a variable in the body Motion Expression:
But it doesn't works.
Do you know haw can I use variables values to use in Expressions?
Thanks!
1 - 1 of 11
    User: "GTT Adam"
    Accepted Answer
    Updated by GTT Adam
    Hi Carlos,
    For variables in the Expression Builder, you usually have to wrap them in curly brackets: { }
    Solver Variables can also be referenced using the VARVAL call: {sv_position.VARVAL}
    Hope this helps!
    Adam Reid
