Hi all,
It's possible to modigy the mesh size in an EDEM geometrie that you can create in the program? (Cylinder, box...).
When you import a geometry you can modify the mesh conditions, but I don't know if ti's possible to select or chage it in a geometry that you create in EDEM like a cylinder.
My problem is, that I amb aplling pressure with a cylinder against a product particles to compress them, and the're some particles that cross the surface of the cylinder, going indise of it.
I want to change the mesh size to try to solve this problem.
Thanks!
