I am trying to compile fluent and EDEM but I keep receiving the following error.
Can you please help me with it ?
You need to use the Visual Studio command prompt rather than windows command prompt. The PDF documentation attached to this case gives an overview:
https://community.altair.com/community/en/edem-fluent-coupling-start-here-compilation-and-set-up?id=kb_article_view&sysparm_article=KB0116548
The last 2 pages outline the error.
Regards
Stephen
Hi, You need to use the Visual Studio command prompt rather than windows command prompt. The PDF documentation attached to this case gives an overview: https://community.altair.com/community/en/edem-fluent-coupling-start-here-compilation-and-set-up?id=kb_article_view&sysparm_article=KB0116548 The last 2 pages outline the error. Regards Stephen
It does not open the link for me and I get the following error but I am logged in
is it possible that I get the access to it ?
Thanks
