Clocking out Signal
Dear Embed support team,
I have a question: I need to clock out data from an ADC therefore I need to be very precise in giving out the right signals at the right time.
I would like to know if Embed can perform or provide any solution or tool to program the correct timing of rising and falling edges of a MCU to give out the signals in the correct order.
I attached a picture of the timing diagramm which I need to program with Altair embed 2021.
Kind regards
Markus
Hi Markus, Which lines are you reading and which lines are you writing?
0 -
Hello Peter,
thank you for your response.
CONVST, CS and RD are the lines I am writing and
BUSY is the line I am reading (and theoretically the parallel Bits (DB0 to DB15)))Kind regards
Markus0 -
Is it possible to time these events with a state machine or is there another solution for timing these events?
Kind regards
Markus0
