In video :“Using S-FRAME's Multistory Builder - Working with Elevation Views”the user use “elevation tool” while I don’t have it How can I create it?
Hello Ali,
Thank you for getting in touch.
Can you confirm which version of S-FRAME you are using (Help-->About S-FRAME)?
The reason I ask is that this elevation tool was introduced in version 2023.0 of S-FRAME (https://community.altair.com/community?id=community_blog&sys_id=4821db701be9f950c4dfdbd9dc4bcbff).
If you are using an older version (V2022.3 or older), this tool will not be available, until you update. Are you able to confirm which version you have?Regards,Matthew Sauer
Altair Support
Hello Ali, Thank you for getting in touch. Can you confirm which version of S-FRAME you are using (Help-->About S-FRAME)? The reason I ask is that this elevation tool was introduced in version 2023.0 of S-FRAME (https://community.altair.com/community?id=community_blog&sys_id=4821db701be9f950c4dfdbd9dc4bcbff). If you are using an older version (V2022.3 or older), this tool will not be available, until you update. Are you able to confirm which version you have?Regards,Matthew Sauer Altair Support
Thank you for your quick response.I am using V2022.3
Thanks for confirming, Ali.
If you'd like to update to the latest version (2023.1) you can find that installation file at the Altair One Marketplace: https://altairone.com/Marketplace
