I want to make a thermal simulation with the solver acusolve in hypermesh. In this simulation i hahave a control volume (water) that flows through a a cold plate i n contact with multiple solids with a heat source. The problem is that when I make the mesh in hypermesh it does not make coincident nodes between txo different volumes, as it does in acuconsole. What should I define te make the nodes in the shared surfaces between different volumes coincident?
Thank you
