Dear sir
First question is that I have modeled direct shear test in Geotechnical engineering but hasn't get needed outputs and I want to know is it possible to model direct shear test by edem software or not and second question is that I have created a python code that used from the uniaxial test in examples of edem software but hasn't get the needed results and if you check this code really appreciate to you.
Best regards
Hi Abbas,
Please see attached EDEM deck and post-processing script for a direct shear test.
Regarding the uniaxial compression test, did you need anything beyond the analysis included in the calibration kit script?
Best regards,
Stefan
