Hex meshing option under 3D ribbon
Is it replaced or moved to somewhere else ?
Hi Satya,
Hex capability was replaced by the more general Extrude tool, in the Topology ribbon.
As you see, Map and Thin Solids are still around in the 3D ribbon for the other hex meshing capabilities.
Please can someone help me, with video or contents on 3D Hex mesh from 2D mesh?
