I've recently installed HyperWorks with a view to giving it a spin, seeing how it performs on Linux & to see how features compare against other products. Hats off to the install chaps, really seamless so far. However, upon first run, first comment there is I had to go digging quite far into the documentation as to how to launch hyperworks, maybe that could be hinted at the end of the install?
Anyhow, the real crux of the issue is that I have a symbol not being found in a shared library, when I run `hwx` I get the following
/opt/altair/2022/altair/scripts/hwx [adavis@j0818 fedora-setup]$ Error loading /opt/altair/2022/altair/hwdesktop/hwx/plugins/hwd/gui/linux64/bin/libhwdplugin.so: /opt/altair/2022/altair/hwdesktop/hwx/plugins/hwd/gui/linux64/bin/libhwdplugin.so: undefined symbol: pthread_mutexattr_setrobust_np Traceback (most recent call last): File "/opt/altair/2022/altair/hwdesktop/hwx/plugins/hwd/InitHwd.py", line 80, in <module> import hwdplugin File "/opt/altair/2022/altair/hwdesktop/hwx/plugins/hwd/gui/linux64/bin/hwdplugin.py", line 28, in <module> _hwdplugin = swig_import_helper() File "/opt/altair/2022/altair/hwdesktop/hwx/plugins/hwd/gui/linux64/bin/hwdplugin.py", line 24, in swig_import_helper _mod = imp.load_module('_hwdplugin', fp, pathname, description) File "/opt/altair/2022/altair/common/python/python3.5/linux64/lib/python3.5/imp.py", line 243, in load_module return load_dynamic(name, filename, file) File "/opt/altair/2022/altair/common/python/python3.5/linux64/lib/python3.5/imp.py", line 343, in load_dynamic return _load(spec) ImportError: /opt/altair/2022/altair/hwdesktop/hwx/plugins/hwd/gui/linux64/bin/libhwdplugin.so: undefined symbol: pthread_mutexattr_setrobust_np Traceback (most recent call last): File "./hwGeneralInit.py", line 6, in <module> File "/opt/altair/2022/altair/hwdesktop/hwx/plugins/hwd/gui/linux64/bin/hwdplugin.py", line 28, in <module> _hwdplugin = swig_import_helper() File "/opt/altair/2022/altair/hwdesktop/hwx/plugins/hwd/gui/linux64/bin/hwdplugin.py", line 24, in swig_import_helper _mod = imp.load_module('_hwdplugin', fp, pathname, description) File "/opt/altair/2022/altair/common/python/python3.5/linux64/lib/python3.5/imp.py", line 243, in load_module return load_dynamic(name, filename, file) File "/opt/altair/2022/altair/common/python/python3.5/linux64/lib/python3.5/imp.py", line 343, in load_dynamic return _load(spec) ImportError: /opt/altair/2022/altair/hwdesktop/hwx/plugins/hwd/gui/linux64/bin/libhwdplugin.so: undefined symbol: pthread_mutexattr_setrobust_np Could not find client named 'HyperWorksDesktop' for loading The missing symbol pthread_mutexattr_setrobust_np is marked as deprecated from gnu c library as of 2021 - https://lists.gnu.org/archive/html/info-gnu/2021-08/msg00001.html
Are my system libraries simply too new for this to work, or is there a simple fix?
