Is that possible to view the 3D pattern of the far field at defined radius ?
In the request far fields parameters, I see only theta and phi that I am able to specify
Many thanks
Hi @AmineSam
You can display the far fields at an offset in POSTFEKO (select the far field in the 3D view, on the ribbon select the Result tab, select Offset and enter the required values). You can also calculate the far fields with an offset by specifying an origin for the far field calculation (on the workplane tab of the far field request dialog in CADFEKO).
Kind regards
Madelé
