I created a .oxps file, but could not open it in either classic or DPS.You can convert it to .pdf or .xps. You can open .xps and .pdf in classic.RegardsMo------------------------------Mahmoud AbdolrahimSenior Implementation & Integration EngineerDatawatch CorporationMA(978) 935-3840-------------------------------------------------------------------------Original Message:Sent: 04-21-2020 07:49 PMFrom: Al RiceSubject: Can Monarch 15 Classic or DPS read .oxps File FormatsHello All:Can Monarch 15 Classic or DPS read .oxps File Formats? I thought I has successfully process such file formats before, but I am drawing a blank at the moment.Thanks in advance for prompt response.Stay safe------------------------------Al Rice------------------------------"
Thanks MoIs there possibility that Altair might consider adding capability to read .oxps file format to its functionality. I haven't run into this often, but maybe others have.Just asking...------------------------------Al Rice-------------------------------------------------------------------------Original Message:Sent: 04-22-2020 08:21 AMFrom: Mahmoud AbdolrahimSubject: Can Monarch 15 Classic or DPS read .oxps File FormatsI created a .oxps file, but could not open it in either classic or DPS.You can convert it to .pdf or .xps. You can open .xps and .pdf in classic.RegardsMo------------------------------Mahmoud AbdolrahimSenior Implementation & Integration EngineerDatawatch CorporationMA(978) 935-3840------------------------------Original Message:Sent: 04-21-2020 07:49 PMFrom: Al RiceSubject: Can Monarch 15 Classic or DPS read .oxps File FormatsHello All:Can Monarch 15 Classic or DPS read .oxps File Formats? I thought I has successfully process such file formats before, but I am drawing a blank at the moment.Thanks in advance for prompt response.Stay safe------------------------------Al Rice------------------------------"
HI @Al Rice, I will forward your request to our Development Team to take the file format into consideration. I will reach out to our Support Team to Create a Support Ticket so we may monitor the status. @Rune Jherd Matas & @Ripan Barot wanted to loop you in on the incoming request. Kindly,Rebecca------------------------------Rebecca CroninCustomer Success & Community ManagerBedford MA(978) 275-8203-------------------------------------------------------------------------Original Message:Sent: 04-22-2020 10:15 PMFrom: Al RiceSubject: Can Monarch 15 Classic or DPS read .oxps File FormatsThanks MoIs there possibility that Altair might consider adding capability to read .oxps file format to its functionality. I haven't run into this often, but maybe others have.Just asking...------------------------------Al Rice------------------------------Original Message:Sent: 04-22-2020 08:21 AMFrom: Mahmoud AbdolrahimSubject: Can Monarch 15 Classic or DPS read .oxps File FormatsI created a .oxps file, but could not open it in either classic or DPS.You can convert it to .pdf or .xps. You can open .xps and .pdf in classic.RegardsMo------------------------------Mahmoud AbdolrahimSenior Implementation & Integration EngineerDatawatch CorporationMA(978) 935-3840Original Message:Sent: 04-21-2020 07:49 PMFrom: Al RiceSubject: Can Monarch 15 Classic or DPS read .oxps File FormatsHello All:Can Monarch 15 Classic or DPS read .oxps File Formats? I thought I has successfully process such file formats before, but I am drawing a blank at the moment.Thanks in advance for prompt response.Stay safe------------------------------Al Rice------------------------------"
