Hi Al,I'm not familiar with AS400, but I do have a question: Are you using Monarch Classic, or Data Prep Studio? There should not be a difference, but there might be.------------------------------Baba MajekodunmiSolutions ConsultantAltair Engineering Inc.Manassas VA978-275-9325-------------------------------------------------------------------------Original Message:Sent: 12-12-2019 08:14 PMFrom: Al RiceSubject: Inconsistent ODBC Connection to AS400 Data TablesHello All:I have several Monarch Models connected to AS400 data tables via ODBC connection. Originally, I mapped a subset of the available fields for use in the Models. Subsequently, for additional data requirements, I added several fields from the AS400 data tables. My problem is the additional fields are not consistently maintained in the database link. I have checked the embedded AS400 login id and password in the ODBC connection and there is no problem there.Hopefully I have described my problem well. Has anyone else experienced such problem and have recommended fix?Thanks in advance for your help.------------------------------Al Rice------------------------------"
Hello Baba MajekodunmiThanks for your reply. Please note that I am using Monarch Classis Version 15.4. Hopefully, I can get some guidance from the community.Thanks,
