Hi, someone of you have some clue about how to solve next issue when running SimSolid. Thank you.
Error code: 5 Unable to write HHWU config
It is a HW Units based license, and the environment variable for license was correctly set.
Please create below environment variable and see if it fixes the issue, if not, you might have to work with your IT team to set proxy settings.
ALM_HHWU_USE_WININET=1
