Combination of 2d and 3d mesh
Giacomo2311
Altair Community Member
i'm a beginner of hypermesh.
I would like to study a 3d component to see the max static stress.
i usually use NX to perform this type of analysis, but now i want to use hypermesh.
In the critical areas, i would like to use 2d mesh with size 1 mm and than creat a 3d mesh on all over the component with size 3 mm.
Is it possible? If yes, how?
In nx we use the command mesh control for example.
Thanks
Kindly refer to the tutorials provided in help menu.
Linear Static Analysis tutorial has been attached for your reference.
Thank You
