Hello!
I'm looking for some assistance on the following matter. Suppose I have two components - one thin (shell) and one thick (3D) which was created by draging 2D element over a certain distance. I want to glue those two components together using 2D area adhesive connector. Can the nodes on the interface of those two components be equivalenced? (they are by default). Shouldn't the nodes on the interface be separate for the stresses in glue connectors to be realiable? If so, is there any way to make them separate? Thank you very much in advance!
