Hello!
Is there a way to create a surface from the outside faces of a solid body? I've included two attachments. I have a solid body on which I would like to lay a surface - thus far I've only managed to extract the midsurface. Maybe there is a way to offset the newly created midsurface so it corresponds to the outside faces of the solid? Thank you in advance.
