I want know how to import an antenna which is already been designed in a third part application into the Altair software and use it for virtual drive test for vehicle to everything application. Detailed work pipeline is much appreciated
Hi @Sidarth Sai ,
To import an antenna from another application into Feko, the easiest way would be to export the geometry and import it into Feko. Alternatively, you could export near-field, far-field or spherical modes (depending on the software) and use them as equivalent source in Feko. Which software is the antenna from?
If you don't refer the question to Feko but to WinProp (I come to it because of "virtual drive test"), then there are possibilities in AMan to convert the antenna patterns for WinProp.
Best regards,Torben
