I've checked the forum on this issue and I see some problems are regarding BCs, material properties and connectors and I am not sure which problem I am facing.
I have attached a screenshot of the error message and attached the output and fem file.
I have tried to add more BCs in case it was under constrained but this did not solve the problem. I will not change the material properties to see if this fixes the problem.
