hello,
i am using a student edition of flux. i am only show the coupled simulation with matlab. i am using 2019 version. to use other softwares what should i do.
Can you give us more precision about other software? Do you want to speak about Altair software’s? If it is the case, there is in Flux supervisor example, examples shows the co-simulation between Flux and other Altair software’s (Activate, Simlab, HyperStudy…etc).
Best regards.
HELLO ABDESSAMED,
SHOULD WE USE COMMANDS OR API FOR THE CO-SIMULATION PROCESS OR DIRECTLY CAN WE COUPLE BOTH OF THEM
If you use Altair softwares, you need to create a connector from Flux and use this connector. To create the connector:
open Flux project >> Solve >> you have all the possiblities to create the connector.
When I try to start Matlab from Flux, Matlab gives me Java errors and Simulink does not start.
Can you send me a screenshot of the error message.
