when we are using stranded coils in 2d models, i f we are not assiginnig any material to it. what will be the default material.
thank you
In the case of stranded coil in Flux 2X, if you don’t put any information about the material, this means that the permeability that you use is 1 (in other hand, thsi means that you use air as material).
Best regards.
ok. if i want to set copper conductors in 2D what steps should i follow.
thanks a lot for your help
When you create a face region type conductor. you put a material (copper)
thanks abdessamed
You are welcome.
