Hello, because I use Winprop to output cell.txt I found that the output content is slightly different. How can I get the RSRQ related information And show Carries in the figure below?
Thanks!
The syntax of the Cells.txt with the unit_impulses SNIR is:
Point coordinates x y z
followed by the sets of
antenna_number carrier_number Signal_level[dBm] SNIR [dB] for each received cell
the last set identifies the serving cell.
In the Cells.txt with the unit_impulses RSRQ/RSRP it is in principle the same:
antenna_number carrier_number RSRP [dBm] RSRQ [dB] for each received cell
Alternatively you can export all the computed network planning results in ASCII files (see check box under the Network tab).
Then you will get the RSRP and RSRQ maps which can be loaded in ProMan via the result tree also as ASCII .txt files.
