I'm using flux 3D for my master thesis. But I met a problem about electric terminal of coil conductor region. When I assigned the terminal, the error happend. It is ' On each volume of this region, the number of points on input faces must be equal to the number of points of the output faces and to the number of lines between the input and output faces. Please, modify the geometry of each volume of this region to resolve correctly this problem.' But this volumen was built by extrusion. So I think the number of points and lines must be equal. How can I solve this problem?
Now I use non meshed coil to take place of these coil conductor regions. But the shape of non meshed coil is not the same as the origninal coils. I don't know, whether the shape of non meshed coil can affect the field?
