I want to simulate an array of Vivaldi antennas, which is obviously very resource intensive. I have read that one can use DGFM to solve antenna arrays and that it will help to run the simulation faster, and with less memory requirements. However, I have also read that you cannot use DGFM with regions that use SEP for certain versions of FEKO and this error message is displayed to me when I run CEM validate in CADFEKO. I have updated my FEKO version - it is FEKO version 2018.2.1-343574 . Is this one of the versions that cannot use SEP and DGFM at the same time? If I cannot use DGFM to solve the array what other methods can I use to help lessen the amount of memory and time resources that is required to simulate the array? Is there a way to fix this? How does this FEKO version relate to FEKO 14 (since I read somewhere that in FEKO 14 this problem was fixed)?
